【AutoCAD二次开发】第六节 块操作
'第六节 块操作
Sub InsertBlock() '插入块
   Dim xy(2) As Double
   xy(0) = 100: xy(1) = 200: xy(2) = 300
   ThisDrawing.Application.ActiveDocument.ModelSpace.InsertBlock xy, _
   "C:\Documents and Settings\Administrator\桌面\abc.dwg", 1, 1, 1, 0
End Sub
Sub BlockProperties() '高程点加常数
    Dim objBlock As AcadBlockReference
    Dim sSet As AcadSelectionSet
    Dim intCnt As Integer
    Dim mType(2) As Integer, mData(2) As Variant
    Dim xyz(2) As Double
    Dim varAttributes As Variant
    intCnt = ThisDrawing.SelectionSets.Count
    While (intCnt > 0)
       Set sSet = ThisDrawing.SelectionSets.Item(intCnt - 1)
       sSet.Delete
       intCnt = intCn0t - 1
    Wend
    mType(0) = 0: mData(0) = "INSERT"
    mType(1) = 8: mData(1) = "GCD"
    mType(2) = 2: mData(2) = "GC200"
    Set sSet = ThisDrawing.SelectionSets.Add("GCD")
    sSet.Select acSelectionSetAll, , , mType, mData
    If sSet.Count > 0 Then
       For Each objBlock In sSet
           xyz(0) = objBlock.insertionPoint(0)
           xyz(1) = objBlock.insertionPoint(1)
           xyz(2) = objBlock.insertionPoint(2) + 50
           objBlock.insertionPoint = xyz '修改高程点的高程值
           varAttributes = objBlock.GetAttributes '获得高程点的块属性
           varAttributes(0).TextString = xyz(2) '修改块属性为新的高程值
       Next
    End If
    sSet.Delete
End Sub
hkai2658 2019-12-21 09:50
等级:LV2
张振川 2019-12-30 09:00
厉害
等级:LV2
张振川 2020-01-10 15:25
intCnt = intCn0t - 1老哥。这里是不是错了。inicnt=inicnt-1
AcadApp: 呵呵,粘贴时多了个0,这都被你发现了,哈哈
2020-01-10 21:07:56
张振川: 老哥,我加您qq您同意一下呀。想跟着您学习
2020-01-13 09:25:20
