【大鹏测绘】根据高程点注记修改高程点高程值
Sub SetGcdHeightByLabel()'根据高程点注记修改高程点高程值
  Dim sSet As AcadSelectionSet
  Dim dType(0 To 2) As Integer, dData(0 To 2) As Variant
  Dim objBlock As AcadBlockReference, iCount As Integer
  Dim varAttributes As Variant, pnt As Variant, i As Integer
  dType(0) = 0: dData(0) = "INSERT"
  dType(1) = 2: dData(1) = "GC200"
  dType(2) = 8: dData(2) = "GCD"
  Set sSet = ThisDrawing.Application.ActiveDocument.SelectionSets.Add("GCD")
  sSet.Select acSelectionSetAll, , , dType, dData
  If sSet.Count = 0 Then
     MsgBox "图形中未发现高程点。", vbInformation, "修改高程点高程值"
  Else
     For Each objBlock In sSet
         varAttributes = objBlock.GetAttributes
         pnt = objBlock.InsertionPoint
         pnt(2) = CDbl(varAttributes(0).TextString)
         objBlock.InsertionPoint = pnt
         i = i + 1
         ThisDrawing.Application.ActiveDocument.Utility.Prompt vbCr & vbCr & "已完成 " & i & "/" & sSet.Count & " ..."
     Next
  End If
  sSet.Delete
End Sub
奔跑蜗牛 2021-02-05 09:19
了解
啊恒15125464119 2021-02-05 10:20
点赞
花好月圆人寿 2021-02-05 17:00
谢谢分享
等级:LV10
新手01579 2022-05-13 14:02
大神,收下我的膝盖
等级:LV10
新手01579 2022-05-13 14:10
是LSP么?怎么执行,报函数错误
