【大鹏测绘】根据高程点高程值修改高程点注记
Sub SetGcdLabelByHeight()'根据高程点高程值修改高程点注记
  Dim sSet As AcadSelectionSet
  Dim dType(0 To 2) As Integer, dData(0 To 2) As Variant
  Dim objBlock As AcadBlockReference, iCount As Integer
  Dim varAttributes As Variant, pnt As Variant, i As Integer
  dType(0) = 0: dData(0) = "INSERT"
  dType(1) = 2: dData(1) = "GC200"
  dType(2) = 8: dData(2) = "GCD"
  Set sSet = ThisDrawing.Application.ActiveDocument.SelectionSets.Add("GCD")
  sSet.Select acSelectionSetAll, , , dType, dData
  If sSet.Count = 0 Then
     MsgBox "图形中未发现高程点。", vbInformation, "修改高程点注记"
  Else
     For Each objBlock In sSet
         varAttributes = objBlock.GetAttributes
         varAttributes(0).TextString = objBlock.InsertionPoint(2)
         i = i + 1
         ThisDrawing.Application.ActiveDocument.Utility.Prompt vbCr & vbCr & "已完成 " & i & "/" & sSet.Count & " ..."
     Next
  End If
  sSet.Delete
End Sub
奔跑蜗牛 2021-02-06 09:31
lh
等级:LV5
新手381613 2021-02-06 09:53
batty 2021-02-06 11:26
厉害
lengxu007 2021-02-06 12:49
谢谢分享
五湖四海 2021-02-06 20:09
感谢分享!
跑杆小王子 2021-02-09 10:24
谢谢分享
等级:LV14
塔漠雀边 2021-04-14 11:41
这个该怎么用?
等级:LV7
yanshe 2022-04-27 00:40
cass里面好像有这个功能吧
