AutoCAD2014安装出现失败怎么办?
新手582184 2021-03-08 10:37
把错误信息的代码上传看看
新手616753: 2021/3/8:14:51:20 Administrator USER-20201231BQ === Setup started on USER-20201231BQ by Administrator === 2021/3/8:14:51:20 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:20 Administrator USER-20201231BQ Current Directory C:\Autodesk\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm 2021/3/8:14:51:20 Administrator USER-20201231BQ Launch 2021/3/8:14:51:20 Administrator USER-20201231BQ CommandLine 2021/3/8:14:51:20 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:20 Administrator USER-20201231BQ Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp 2021/3/8:14:51:37 Administrator USER-20201231BQ === Setup ended === 2021/3/8:14:51:31 Administrator USER-20201231BQ === Setup started on USER-20201231BQ by Administrator === 2021/3/8:14:51:31 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:31 Administrator USER-20201231BQ Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp 2021/3/8:14:51:31 Administrator USER-20201231BQ Launch 2021/3/8:14:51:32 Administrator USER-20201231BQ Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp\Setup\AcSetup.dll 2021/3/8:14:51:32 Administrator USER-20201231BQ Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2021/3/8:14:51:37 Administrator USER-20201231BQ PageOpen LaunchDialog 2021/3/8:14:51:41 Administrator USER-20201231BQ PageOpen LicenseDialog 2021/3/8:14:51:44 Administrator USER-20201231BQ PageOpen ProductInfoDialog 2021/3/8:14:51:54 Administrator USER-20201231BQ PageOpen ProductSelectionDialog2 2021/3/8:14:51:57 Administrator USER-20201231BQ PageOpen FullProgressDialog 2021/3/8:14:51:57 Administrator USER-20201231BQ Installing .NET Framework Runtime 4.0: "C:\Autodesk\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe" /q 2021/3/8:14:52:50 Administrator USER-20201231BQ Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2021-03-08 14:54:05
大杨树 2021-03-08 16:10
安装 .NET Framework Runtime 4.0失败,可能是你的操作系统版本比较高,AutoCAD2014所带安装程序比较老,二者不匹配造成的,到网上搜索一下安装.NET Framework Runtime 4.0的办法吧。
岩柯 2021-03-09 06:15
选择别的版本
工程测绘 2021-03-09 07:37
选择脚本
hkai2658 2021-03-09 07:43
阅读
GeoData 2021-03-22 06:39
先下载运行库安装好
新手9019 2021-05-16 10:05
