WIN10系统64位安装CAD2014出错
Autodesk® AutoCAD® 2014
Error 2229.Database: . Could not load table 'InstallExecuteSequence' in SQL query: SELECT `Action`,NULL,`Condition` FROM `InstallExecuteSequence` WHERE `Sequence` > 0 ORDER BY `Sequence`.
确定
显示这个,错误报告提示
2018/12/28:11:17:35 Administrator WIN10-808172034 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2018/12/28:11:17:35 Administrator WIN10-808172034 Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="D:\BMF2014CAD2014\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2018/12/28:11:18:23 Administrator WIN10-808172034 Install Autodesk Material Library 2014 Succeeded
2018/12/28:11:18:24 Administrator WIN10-808172034 Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=zh-cn SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="D:\BMF2014CAD2014\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2018/12/28:11:21:15 Administrator WIN10-808172034 Install Autodesk Material Library 2014 - Base Image Library Failed Installation aborted, Result=1603
2018/12/28:11:21:52 Administrator WIN10-808172034 Rollback Autodesk Material Library 2014 Succeeded
2018/12/28:11:21:58 Administrator WIN10-808172034 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2018/12/28:11:21:58 Administrator WIN10-808172034 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
奔跑蜗牛 2018-12-28 16:12
是不是CAD没有安装完善,建议重新安装,换个低点CAD也可以。
开心每一天 2018-12-28 20:07
建议重新下载别的网站的CAD2014的试试!
等级:LV16
漂泊 2019-01-02 07:12
报错的内容是没看懂,不过一般解决办法就是卸载,清理注册表,重新安装。安装时候注意提示,缺少其他组件会提示自行下载安装,不要拒绝。
新手842019 2021-04-11 18:02
Autodesk® AutoCAD® 2014 32&64:
最高支持 Windows 7
