[CASS二次开发源代码]VB6+AutoCAD---图层控制
Public Sub ILayerOn(ByVal AcadApp As Object) '图层全开
  Dim objLyr As Object
  For Each objLyr In AcadApp.Application.ActiveDocument.Layers
      objLyr.LayerOn = True
  Next
End Sub
Public Sub ILayerOff(ByVal AcadApp As Object) '图层选关
  Dim objLyr As Object, objEnt As Object, sSet As Object
  For Each sSet In AcadApp.Application.ActiveDocument.SelectionSets
      If sSet.Name = "ILayerOff" Then sSet.Delete: Exit For
  Next
  Set sSet = AcadApp.Application.ActiveDocument.SelectionSets.Add("ILayerOff")
  sSet.SelectOnScreen
  If sSet.Count > 0 Then
     For Each objEnt In sSet
             If objLyr.Name = objEnt.Layer Then
                objLyr.LayerOn = False
             End If
         Next
     Next
  End If
  sSet.Delete
End Sub
Public Sub ILayerOffExcept(ByVal AcadApp As Object) '图层指定外关闭
      If sSet.Name = "ILayerOffExcept" Then sSet.Delete: Exit For
  Next
  Set sSet = AcadApp.Application.ActiveDocument.SelectionSets.Add("ILayerOffExcept")
  sSet.SelectOnScreen
             If objLyr.Name <> objEnt.Layer Then
             End If
         Next
     Next
  End If
  sSet.Delete
End Sub
Public Sub ILayerLock(ByVal AcadApp As Object) '图层锁定
      If sSet.Name = "ILayerLock" Then sSet.Delete: Exit For
  Next
  Set sSet = AcadApp.Application.ActiveDocument.SelectionSets.Add("ILayerLock")
  sSet.SelectOnScreen
                objLyr.Lock = True
             End If
         Next
     Next
  End If
  sSet.Delete
End Sub
Public Sub ILayerUnlock(ByVal AcadApp As Object) '图层开锁
      objLyr.Lock = False
  Next
End Sub
Public Sub ILayerFreeze(ByVal AcadApp As Object)    '图层冻结
  Dim objEnt As Object, objLyr As Object, pnt As Variant, sSet As Object
      If sSet.Name = "ILayerFreeze" Then sSet.Delete: Exit For
  Next
  Set sSet = AcadApp.Application.ActiveDocument.SelectionSets.Add("ILayerFreeze")
  sSet.SelectOnScreen
                If AcadApp.Application.ActiveDocument.ActiveLayer.Name <> objLyr.Name Then
                   objLyr.Freeze = True
                End If
             End If
         Next
     Next
  End If
  sSet.Delete
End Sub
Public Sub ILayerUnfreeze(ByVal AcadApp As Object)     '图层解冻
      If objLyr.Freeze = True Then objLyr.Freeze = False
  Next
  AcadApp.Application.ActiveDocument.Regen acActiveViewport
End Sub
Public Sub ILayerCur(ByVal AcadApp As Object)   '图层当前
  On Error Resume Next
  AcadApp.Application.ActiveDocument.Utility.GetEntity objEnt, pnt, vbCr & vbCr & "选择对象:"
  If Err Then Err.Clear: Exit Sub
  Set objLyr = AcadApp.Application.ActiveDocument.Layers(objEnt.Layer)
  AcadApp.Application.ActiveDocument.ActiveLayer = objLyr
End Sub
hkai2658 2019-12-11 08:35
没有看懂
