AutoCAD2014安装出现失败怎么办?
时间:2021-03-08 10:33
作者:新手616753
阅读:4104
悬赏分
:30 积分
2021-03-08 10:37
把错误信息的代码上传看看
新手616753
2021/3/8:14:51:20 Administrator USER-20201231BQ === Setup started on USER-20201231BQ by Administrator === 2021/3/8:14:51:20 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:20 Administrator USER-20201231BQ Current Directory C:\Autodesk\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm 2021/3/8:14:51:20 Administrator USER-20201231BQ Launch 2021/3/8:14:51:20 Administrator USER-20201231BQ CommandLine 2021/3/8:14:51:20 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:20 Administrator USER-20201231BQ Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp 2021/3/8:14:51:37 Administrator USER-20201231BQ === Setup ended === 2021/3/8:14:51:31 Administrator USER-20201231BQ === Setup started on USER-20201231BQ by Administrator === 2021/3/8:14:51:31 Administrator USER-20201231BQ Path_Length: 155 2021/3/8:14:51:31 Administrator USER-20201231BQ Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp 2021/3/8:14:51:31 Administrator USER-20201231BQ Launch 2021/3/8:14:51:32 Administrator USER-20201231BQ Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIEAF1.tmp\Setup\AcSetup.dll 2021/3/8:14:51:32 Administrator USER-20201231BQ Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2021/3/8:14:51:37 Administrator USER-20201231BQ PageOpen LaunchDialog 2021/3/8:14:51:41 Administrator USER-20201231BQ PageOpen LicenseDialog 2021/3/8:14:51:44 Administrator USER-20201231BQ PageOpen ProductInfoDialog 2021/3/8:14:51:54 Administrator USER-20201231BQ PageOpen ProductSelectionDialog2 2021/3/8:14:51:57 Administrator USER-20201231BQ PageOpen FullProgressDialog 2021/3/8:14:51:57 Administrator USER-20201231BQ Installing .NET Framework Runtime 4.0: "C:\Autodesk\AutoCAD_2014_Simplified_Chinese_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe" /q 2021/3/8:14:52:50 Administrator USER-20201231BQ Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2021-03-08 14:54:05
安装 .NET Framework Runtime 4.0失败,可能是你的操作系统版本比较高,AutoCAD2014所带安装程序比较老,二者不匹配造成的,到网上搜索一下安装.NET Framework Runtime 4.0的办法吧。
2021-03-09 06:15
选择别的版本
选择脚本
阅读
GeoData
2021-03-22 06:39
先下载运行库安装好
新手9019
2021-05-16 10:05
悬赏积分获取规则
安装了AutoCAD2014,Cass应该安装哪个版本呀?
阅读:9720
cad安装失败,提示net失败
阅读:2626
安装cad失败,提示1904,怎么办?
阅读:4488
新手616753
【分享】租赁版CASS激活后仍有"激活文件下载"提示
【分享】中望版本CASS11.0看不到命令行
【分享】提取出的高程Z值不对(XY坐标正确)
【分享】CASS11 运行时弹窗报错"无写入权限"
电子水准仪使用说明书
