H3C无法打开web页面,我把配置贴在下面请工程师帮我看看
  dis cu
  version 7.1.064, Release 9333P26
  clock timezone UTC add 08:00:00
  context Admin id 1
  irf mac-address persistent timer
  irf auto-update enable
  undo irf link-delay
  irf member 1 priority 32
  irf member 2 priority 1
  ospf 10
  area 0.0.0.0
  network 192.168.10.1 0.0.0.0
  ip unreachables enable
  ip ttl-expires enable
  nat port-block synchronization enable
  lldp global enable
  password-recovery enable
  vlan 1
  vlan 1001
  description BFD¼ì²â
  irf-port 1/2
  port group interface GigabitEthernet1/0/14
  port group interface GigabitEthernet1/0/15
  irf-port 2/1
  port group interface GigabitEthernet2/0/14
  port group interface GigabitEthernet2/0/15
  object-group service ¸ßΣ
  0 service tcp destination range 135 139
  10 service udp destination range 135 139
  20 service tcp destination eq 445
  30 service udp
  40 service tcp destination eq 177
  60 service tcp destination eq 593
  policy-based-route neiwang permit node 5
  if-match acl 3000
  apply next-hop 58.53.167.181
  policy-based-route neiwang permit node 10
  if-match acl 3001
  apply next-hop 10.10.1.1
  interface Reth1
  ip address 192.168.10.1 255.255.255.0
  member interface Route-Aggregation1 priority 255
  member interface Route-Aggregation2 priority 1
  nat hairpin enable
  interface NULL0
  interface Vlan-interface1001
  description BFD¼ì²â
  mad bfd enable
  mad ip address 192.168.101.5 255.255.255.0 member 1
  mad ip address 192.168.101.6 255.255.255.0 member 2
  interface GigabitEthernet1/0/0
  port link-mode route
  ip address 192.168.0.1 255.255.255.0
  ip address 1.1.1.1 255.255.255.252
  interface GigabitEthernet1/0/2
  interface GigabitEthernet1/0/4
  port link-aggregation group 1
  interface GigabitEthernet1/0/5
  interface GigabitEthernet1/0/6
  interface GigabitEthernet1/0/7
  interface GigabitEthernet1/0/8
  interface GigabitEthernet1/0/9
  interface GigabitEthernet1/0/10
  interface GigabitEthernet1/0/11
  description ceshi
  ip address 172.16.1.1 255.255.255.252
  interface GigabitEthernet1/0/12
  ip address 10.10.1.2 255.255.255.0
  nat outbound
  interface GigabitEthernet1/0/13
  ip address 58.53.167.185 255.255.255.224
  ip last-hop hold
  nat outbound
  interface GigabitEthernet1/0/16
  interface GigabitEthernet1/0/17
  interface GigabitEthernet1/0/18
  interface GigabitEthernet1/0/19
  interface GigabitEthernet1/0/20
  interface GigabitEthernet1/0/21
  interface GigabitEthernet1/0/22
  interface GigabitEthernet1/0/23
  interface GigabitEthernet2/0/0
  interface GigabitEthernet2/0/2
  interface GigabitEthernet2/0/4
  port link-aggregation group 2
  interface GigabitEthernet2/0/5
  interface GigabitEthernet2/0/6
  interface GigabitEthernet2/0/7
  interface GigabitEthernet2/0/8
  interface GigabitEthernet2/0/9
  interface GigabitEthernet2/0/10
  interface GigabitEthernet2/0/11
  interface GigabitEthernet2/0/12
  interface GigabitEthernet2/0/13
  interface GigabitEthernet2/0/16
  interface GigabitEthernet2/0/17
  interface GigabitEthernet2/0/18
  interface GigabitEthernet2/0/19
  interface GigabitEthernet2/0/20
  interface GigabitEthernet2/0/21
  interface GigabitEthernet2/0/22
  interface GigabitEthernet2/0/23
  interface GigabitEthernet1/0/3
  port link-mode bridge
  description BFD¼ì²â
  port access vlan 1001
  undo stp enable
  interface GigabitEthernet2/0/3
  description BFD¼ì²â
  undo stp enable
  security-zone name Local
  attack-defense apply policy test
  security-zone name Trust
  import interface GigabitEthernet1/0/1
  import interface GigabitEthernet1/0/11
  import interface Reth1
  security-zone name DMZ
  security-zone name Untrust
  import interface GigabitEthernet1/0/12
  import interface GigabitEthernet1/0/13
  security-zone name Management
  import interface GigabitEthernet1/0/0
  scheduler logfile size 16
  line class aux
  user-role network-operator
  line class console
  authentication-mode scheme
  user-role network-admin
  line class usb
  line class vty
  line aux 0
  line aux 1
  line con 0 1
  line vty 0 4
  idle-timeout 15 0
  line vty 5 63
  snmp-agent
  snmp-agent local-engineid 800063A28074504EBFD1D400000001
  snmp-agent community write private
  snmp-agent community read public
  snmp-agent sys-info version v2c v3
  snmp-agent target-host trap address udp-domain 172.20.1.101 params securityname public v2c
  snmp-agent target-host trap address udp-domain 172.21.1.101 udp-port 5000 params securityname public
  snmp-agent trap enable arp
  snmp-agent trap enable radius
  snmp-agent trap enable stp
  snmp-agent trap enable syslog
  ssh server enable
  ntp-service enable
  ntp-service unicast-server 172.20.1.101
  acl basic 2000
  description WiFi
  rule 5 permit source 172.10.32.0 0.0.15.255
  rule 10 permit source 172.10.16.0 0.0.15.255
  acl basic 2001
  rule 5 permit source 172.20.4.0 0.0.0.255
  acl advanced 3000
  description У԰WiFi
  rule 5 permit ip source 172.10.32.0 0.0.15.255
  rule 10 permit ip source 172.10.16.0 0.0.15.255
  acl advanced 3001
  description °à°àͨ
  rule 5 permit ip source 172.20.4.0 0.0.0.255
  password-control enable
  undo password-control aging enable
  undo password-control history enable
  password-control length 8
  password-control login-attempt 3 exceed lock-time 30
  password-control update-interval 0
  domain system
  domain default enable system
  role name level-0
  description Predefined level-0 role
  role name level-1
  description Predefined level-1 role
  role name level-2
  description Predefined level-2 role
  role name level-3
  description Predefined level-3 role
  role name level-4
  description Predefined level-4 role
  role name level-5
  description Predefined level-5 role
  role name level-6
  description Predefined level-6 role
  role name level-7
  description Predefined level-7 role
  role name level-8
  description Predefined level-8 role
  role name level-9
  description Predefined level-9 role
  role name level-10
  description Predefined level-10 role
  role name level-11
  description Predefined level-11 role
  role name level-12
  description Predefined level-12 role
  role name level-13
  description Predefined level-13 role
  role name level-14
  description Predefined level-14 role
  user-group system
  local-user admin class manage
  service-type ssh terminal https
  authorization-attribute user-role network-admin
  local-user root class manage
  authorization-attribute user-role network-operator
  password-control login-attempt 2 exceed lock
  session statistics enable
  session synchronization enable
  session synchronization dns http
  ipsec redundancy enable
  ipsec logging negotiation enable
  ike logging negotiation enable
  ip https port 8443
  ip https enable
  webui log enable
  blacklist global enable
  attack-defense policy test
  scan detect level medium action logging block-source
  app-profile 1_IPv4
  ips apply policy default mode protect
  anti-virus apply policy default mode protect
  app-profile 2_IPv4
  app-profile 6_IPv4
  inspect logging parameter-profile av_logging_default_parameter
  inspect logging parameter-profile ips_logging_default_parameter
  inspect logging parameter-profile url_logging_default_parameter
  loadbalance isp file flash:/lbispinfo_v1.5.tp
  traffic-policy
  rule 1 name ÏÞËÙ²ßÂÔ
  action qos profile ÏÞËÙͨµÀ
  source-zone Truns
  destination-zone Untrust
  profile name ÏÞËÙͨµÀ
  bandwidth downstream guaranteed 10000000
  bandwidth downstream maximum 10000000
  bandwidth upstream guaranteed 10000000
  bandwidth upstream maximum 10000000
  bandwidth upstream guaranteed per-ip 20480
  bandwidth upstream maximum per-ip 20480
  bandwidth downstream guaranteed per-ip 40960
  bandwidth downstream maximum per-ip 40960
  security-policy ip
  rule 1 name trust-untrust
  action pass
  logging enable
  counting enable
  profile 1_IPv4
  source-zone Trust
  destination-zone Local
  rule 2 name untrust-trust
  action pass
  logging enable
  counting enable
  profile 2_IPv4
  source-zone Untrust
  destination-zone Trust
  service ssh
  service-port tcp destination eq 8443
  service-port tcp destination eq 9443
  service-port tcp destination eq 22
  service-port tcp destination eq 7443
  service-port tcp destination eq 443
  service-port tcp destination eq 65443
  ---- More ----%Nov 2 10:28:28:358 2024 Fxyz_JYW_FW SSHS/6/SSHS_LOG: -COntext=1; Connection closed by 79.110.62.93.
  service-port tcp destination eq 9500
  service-port tcp destination range 9000 9400
  ---- More ----%Nov 2 10:28:28:359 2024 Fxyz_JYW_FW SSHS/6/SSHS_DISCONNECT: -COntext=1; SSH user (IP: 79.110.62.93) disconnected from the server.
  service-port tcp destination eq 8081
  service-port tcp destination range 61616 61617
  service-port tcp destination eq 50001
  service-port tcp destination range 3121 3123
  service-port tcp destination eq 9902
  service-port tcp destination eq 8083
  service-port tcp destination eq 1935
  service-port tcp destination eq 6080
  service-port tcp destination range 5555 5570
  service-port tcp destination eq 6060
  service-port tcp destination eq 3389
  service-port tcp destination eq 9022
  service-port tcp destination eq 8080
  service-port udp destination range 60000 65000
  service-port udp destination eq 9902
  rule 6 name local-any
  action pass
  logging enable
  counting enable
  profile 6_IPv4
  source-zone Local
  rule 7 name ¸ßΣ¶Ë¿Ú
  counting enable
  source-zone Untrust
  service ¸ßΣ
  ips logging parameter-profile ips_logging_default_parameter
  anti-virus logging parameter-profile av_logging_default_parameter
  return
暂无评论
