【源代码分享】显示CAD选择集夹持点
Public Sub ShowSelectionSetCrips(ByVal AcadApp As AcadApplication, ByRef ss As AcadSelectionSet)
  Dim objEnt As AcadEntity
  EvalLispExpression AcadApp, "(setq ss (ssadd))"
  For Each objEnt In ss
      EvalLispExpression AcadApp, "(ssadd " & _
                                "(handent " & Chr(34) & _
                                objEnt.Handle & Chr(34) & ")" & _
                                "ss" & _
  Next
  EvalLispExpression AcadApp, "(sssetfirst nil ss)"
  EvalLispExpression AcadApp, "(setq ss nil)"
End Sub
Public Function EvalLispExpression(ByVal AcadApp As AcadApplication, lispStatement As String)
  Dim VL As Object, VLF As Object
  Dim sym As Object, ret As Object, retVal
  Select Case Val(Left(AcadApp.Application.Version, 2))
    Case Is = 15
         Set VL = AcadApp.Application.GetInterfaceObject("VL.Application.1")
    Case Is >= 16
         Set VL = AcadApp.Application.GetInterfaceObject("VL.Application.16")
  End Select
  Set VLF = VL.ActiveDocument.Functions
  Set sym = VLF.Item("read").funcall(lispStatement)
  On Error Resume Next
  retVal = VLF.Item("eval").funcall(sym)
  If Err Then
     EvalLispExpression = ""
  Else
     EvalLispExpression = retVal
  End If
  On Error GoTo 0
End Function
Public Sub TestC(ByVal AcadApp As AcadApplication)
  Dim sSet As AcadSelectionSet
  For Each sSet In AcadApp.Application.ActiveDocument.SelectionSets
      If sSet.Name = "TESTC" Then sSet.Delete: Exit For
  Next
  Set sSet = AcadApp.Application.ActiveDocument.SelectionSets.Add("TESTC")
  sSet.Select acSelectionSetAll
  ShowSelectionSetCrips AcadApp, sSet
  sSet.Delete
End Sub
(defun c:TestC( / rndobj)
  (vl-load-com)
  (setq rndobj (vlax-get-or-create-object "TestX.TestB"))
  (vlax-invoke-method rndobj "TestC" (vlax-get-acad-object))
  (vlax-release-object rndobj)
  (princ)
regsvr32 /s TestX.dll
奔跑蜗牛 2019-12-12 09:09
